Old 11-14-2018, 08:28 AM
lr172 lr172 is offline
Default Determining resistor size
I am installing a fan in the dash of the 10. It is a 120mm fan and want it to run slowly most times and full blast when needed via switch. Plan to run the full 12v through one side of the DT switch and 4.5v through the other side. I have tested this on the bench and like the flow at 4.5 volts drawing 100 mA. This was tested using an LM317 in constant voltage mode.
My question is what size resistor do I need to get my 14 volt buss voltage down to 4.5 volts? Also, for computing the power for sizing, can I use the current observed at 4.5v on the LM317 based power supply?
I could use an LM317 for this, but would like to avoid throwing a little board in the harness if I can.
N64LR
RV-10 in progress
Old 11-14-2018, 08:45 AM
Mike S Mike S is online now
I would stick a 0-10k pot in there, adjust the pot to give the voltage or fan speed you want.
Measure the value on the pot.
Buy a resistor of that value.
Or, just keep the pot in place of a switch and resistor??
Old 11-14-2018, 09:05 AM
Carl Froehlich's Avatar
Two speed fan(s) are really not needed.
One fan (RV-8) or two fans (side by side RVs) under the glareshield with a nice hole pattern instead of a fan screen, then just an on/off switch, Summer leave the fan on to move the avionics heat from behind the panel, winter just for those few minutes you need defrost.
No need for huge fan(s), just something to move a little air. In the RV-8 I use a single 2 fan. On the RV-10 I used two 3 fans.
Old 11-14-2018, 11:35 AM
14.5 volts minus 4.5V fan = 10 volts dropped by resistor.
10 volts / 0.100 amps = 100 ohm resistor
The resistor will get hot if it is low wattage.
How about 5 watt rating or more?
Or search Amazon or eBay for DC Fan Speed Controller.
Joe Gores
RV-12 Flying
Old 11-14-2018, 11:41 AM
Make your own PWM fan speed controller using a TC648
Joe Gores
RV-12 Flying
Old 11-14-2018, 02:43 PM
Thanks for the input. I just remembered that I have a 3.3V power supply that I am installing to power my headset. I will run the fan directly off that supply. 3.3 still seems to push enough air for avionics ventilation.
N64LR
RV-10 in progress
Old 11-14-2018, 02:52 PM
FasGlas's Avatar
FasGlas FasGlas is offline
LM7805 regulator is a buck and would work fine.
Old 11-14-2018, 03:03 PM
fl-mike's Avatar
fl-mike fl-mike is offline
run it full speed all the time. KISS.
Once that big fan up front is turning, any noise is insignificant. Power consumption will be constant unless you use a switcher supply. i.e. you're just dropping voltage via heat in the dropping circuit.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage in progress.
Old 11-15-2018, 03:58 AM
maniago's Avatar
maniago maniago is offline
....and you have a headset on.....how will you determine that you should be at low speed or high speed on your fan anyway? Not pointing fingers, just curious as to why you might want to do this.....I have 4 very small fans under the glare shield and one on each of my 3 buss solenoids in the engine compartment - they all run full bore all the time, tho probably dont need to..... .25-.5amp total.
Mani
MustangII (FoldingWing) "Finishing up": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI,wet compass
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 11-15-2018, 12:23 PM
Thanks for the input. This fans moves a lot of air that just isn't necessary for cooling, but is for defrost purposes. I suppose it is no big deal to run full bore at all times. Certainly wasn't concerned about the noise; More about blowing on my face and sucking power.
N64LR
RV-10 in progress
