360M1B ?
birddog486
I need a measurement of the thickness of the ring gear assy. where it bolts to the crankshaft flange. IOW: how thick is the flywheel?
I just measured a Superior Air Parts starter ring gear and came up with similar reading. 0.2516" using my micrometer. If I ran some scotch bright over mine, I expect that I would get a slightly smaller reading.
The part I measured was removed from an engine that was removed from a flying airplane yesterday and has had no cleaning. I was wiped with a RED rag and measured.
