Old 11-02-2018, 03:24 PM
Stockmanreef Stockmanreef is offline
Default 390 Engine Question
I plan to put dual PMags on the IO 390 with a Hartzell constant speed prop. Is there any issue with this setup from an FAA point of view. A person in the UK indicated that he would not be allowed to use that setup since that particular setup has not been tested over in the UK.
I can change to regulator Mag and a PMag at this point if need be.
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 11-02-2018, 03:56 PM
DanH's Avatar
DanH DanH is offline
There is no FAA issue.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-02-2018, 04:13 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default That's what I have...
The P-mags have seasoned well and are a mature product at this point.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
flying with more than 1,935 on the hobbs
Race 771
margarita!
Old 11-02-2018, 04:32 PM
Chris Cooper Chris Cooper is offline
Hartzell say they havenít tested with electronic ignition. Iím guessing they donít mean p-mags?
Chris Cooper
RV14 - building
www.vansrv14.uk
RV3A - bought
Old 11-02-2018, 04:48 PM
DanH's Avatar
They most definitely mean p-mags.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-02-2018, 05:06 PM
Chris Cooper
RV14 - building
www.vansrv14.uk
RV3A - bought
Old 11-02-2018, 05:33 PM
should I post this on the general forums to get a broader audience to chime in?
Ken Stockman
Midland, MI
Old 11-02-2018, 05:53 PM
Kyle Boatright Kyle Boatright is online now
No need. It is an experimental airplane. For ignition, you could legally install a big sparkler and the FAA wouldn't interfere.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-02-2018, 05:57 PM
OK--point taken, but what about the Hartzell note below. Is this just a CYA for Hartzell?
Ken Stockman
Midland, MI
Old 11-02-2018, 06:51 PM
I think their point is "We haven't tested it." (And we're not going to guess.)
So probably, but vibration is a weird thing. As far as I know, experience in the field doesn't seem to show any ignition driven problems with the props.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
