Old 10-22-2018, 02:10 PM
mjanduda's Avatar
mjanduda mjanduda is offline
Default Van's stress analysis public?
Hey Builders,
do you know if the stress analysis for Van's RV airplanes is public?
Where can I find them? I'd like to have a look at them
Best,
Malte
Old 10-22-2018, 04:42 PM
Ralph Inkster Ralph Inkster is offline
I doubt it. Multiple legal & proprietary reasons alone would be reason enough to keep this type engineering data out of the the public domain.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 10-26-2018, 11:36 AM
RV-14E's Avatar
RV-14E RV-14E is offline
Next time you land hard in your RV-14, remember the abuse Van's subjected the design to in this 7m13s YouTube video they shared with the community:
RV-14 Drop Testing
"The RV-14 underwent a tremendous amount of testing and abuse before going out the door!"
E
http://rv-14a.blogspot.com/
Old 10-26-2018, 12:28 PM
mjanduda's Avatar
Have they stressed the 14 gear for 2050 lbs MTOW?
Or have they added some margin?
Would the gear be a limiting factor when it comes to increasing the mtow because it's only tested for 2050lbs?
Old 10-26-2018, 12:42 PM
The limiting factor to the published gross weight is the entire airplane.
A proper design process uses the design gross weight in designing everything... airplanes aren't designed and then tested, and then a max weight set based on what the weakest was shown to be as a result of the tests done.
Scott McDaniels
Hubbard, Oregon
Old 10-26-2018, 03:42 PM
thilokind thilokind is offline
There is a complete stress analysis for an RV 7 (if I remember correctly) done by an engineering student in Germany. The analysis is available from the OUV (the German version of the EAA). www.ouv.de
Old 10-26-2018, 04:10 PM
JonJay's Avatar
JonJay JonJay is offline
Scott - what was the tire pressure used in the test? (Curious from another thread).
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-27-2018, 09:27 AM
Snowflake's Avatar
The University of British Columbia's Aero Design course used an RV-6 as the example aircraft for the class after mine (ours used the Murphy Rebel). I don't know exactly what they did, but we analysed the entire Rebel structure, and played with configuration to see what trade-offs could be made. I don't know how much of that work is available anywhere.
Rob Prior
