Old 11-08-2018, 11:09 AM
bcondrey bcondrey is offline
So, 2 different things being discussed...
1) a warning system to ensure the front and back pins are engaged is provided with the kit. It uses magnets in the pins and reed switches to detect them. If a door doesnít have BOTH pins engaged, an LED will illuminate. Alternatively, or in addition to, you can drive discreet inputs on a G3x or other device.
2) mechanical door closure system: Vans designed their middle latch to ensure complete closure (there has been at least 1 aircraft with it installed that lost a door anyway. PlaneAround has a really nice center latch system thatís integrated with the stock closure mechanism. In addition to holding the door closed, it actually pulls the door shut when the stock handle is rotated into the closed position. With this system installed, itís not possible to have the typical issue that allows a door to depart the aircraft (front pin engaged, aft pin outside the aircraft). The PlaneAround design is MUCH nicer than the Vans afterthought. Further, PlaneAround also makes longer pins that extend further into the frame than stock.
In summary, the PlaneAround center latch should be considered a must have for -10 builders. For those that donít choose this path, door pin extension into door frames should be confirmed during construction. Further, preflight check should be done on front AND aft pins (both doors) to confirm closure. Regardless of latching system, the interior handles should also be checked to confirm fully latched.
Bob
RV-10 (#2) N2622S
Old 11-08-2018, 11:15 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by Mike S View Post
Why do you use a check list in the first place???
Is it not to make sure you have checked things, and assured that they are working correctly before you take an action------Start Engine list, Takeoff list, Landing list etc.
We could just forget the check lists, and wait for the engine to get quiet or other things to go wrong and activate a warning light
Besides, I just simply do not like using power continuously for the purpose of turning a light off.
Anyway, this is just what I did, you are free do do it however makes sense to you.
My suggestion was much closer to the dome light system in your car.
Warning lights on the panel sort of over-ride check lists - that why we make them red...
No power is consumed when the doors are closed - that was for Vans system with relays.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-08-2018, 11:39 AM
Yep, yet another way to de-fur the feline.
Old 11-08-2018, 01:04 PM
Default Correction.....
The middle latch was designed to be a passive back-up in case the door isn't correctly latched.
It doesn't ensure complete closure of the door.
As far as it not preventing at least one door loss.... The fact that these airplanes are in reality amateur built can be an explanation for an occasional failure. I am not meaning that it is a certainty, because the safety latch was not extensively flight tested, but it can't be discounted either since there have also been cases where the safety latch did save the door from being lost.
Scott McDaniels
Hubbard, Oregon
Old 11-08-2018, 01:14 PM
the system was specifically designed the way it is, to help mitigate a false safe indication caused by a variety of failure types within the system (broken wire, shorted wire, etc.)
I have no idea if the system has be redesigned since I did mine.
As I remember this, (10 years or so since I installed the warning lights) the power for the light and relay is from the same source. Thus a broken wire here can cause a false safe indication. Also a broken wire from the relay to the LED will cause a false safe indication.
Consider this; I pull the plane out to go fly and do my walk around----all good so I get in and shut the doors. I flip on the master, and while waiting for the EFIS to boot up I start the check list. Right at the top is "Check Doors" I push the button, and get two green. At that time I know the doors are secure. If I do not get two green, I know there is a problem.
Now, same scenario with factory automatic red warning lights. I pull the plane out to go fly and do my walk around----all good so I get in and shut the doors. I flip on the master, and while waiting for the EFIS to boot up I start the check list. Right at the top is "Check Doors". I glance at the warning lights, and they are not on. All I really know at the moment is the lights are not on------but I have no idea if the system is actually working as designed or if there is a broken wire or a failed light.
I suppose it would be possible to put in both a green light for latched and a red for not latched, and drive the green from the N.O. contact of the relay. Might be a better system------after all, lots of things in the plane have booth red and green indications, oil temp and pressure gauges comes to mind.
As I said previously;
Old 11-08-2018, 02:28 PM
Carl Froehlich's Avatar
This is a lot of discussion on what has been previously hashed out. The RV-10 doors are problematic, steps must be taken to mitigate this risk but a proven path has already been identified. Iíll summarize:
- Plane around center cam. This is simply a must do. The Vanís after thought SB safety door latch is marginal at best, and just not acceptable on these $200K airplanes.
- Each door pin has a magnet that closes itís own micro switch. The switches are wired in series so that only all four pins properly in place will yield the doors shut indication. For the vast majority of builders this signal is used to activate an EFIS input (so no extra relays or LEDs required or desired). On the SkyView I have a red indication on the EMS display, once all the doors pins are in it goes to green. Just about as simple as it gets.
Old 11-08-2018, 02:36 PM
Paddy's Avatar
Paddy Paddy is offline
Default Door Warning
I used the PlaneAround latch and can't rotate the handle unless both pins are engaged and the cam is in place on the block. For a backup, the rear pins contact a mechanical microswitch wired to the G3X so that there's a CAS on the EFIS which also illuminates the Master Warning light on the panel. This same Master Warning light is used to alert for low oil pressure, below min fuel and other can't-be-missed info. Just another way to solve for the same problem.
Flying as of 10/30/16 after 8 yrs building
Old 11-08-2018, 02:57 PM
woxofswa woxofswa is offline
In my humble opinion Vanís should adopt the plarne around system and the Andair fuel valve as standard kit issue just like they did with the Vetterman exhaust.
I love Vanís company and my RV10, but was sorely disappointed with the ugly door latch ďfixĒ, especially with how elegant, simple, and effective the plane around system is for not much more installation effort. I like cheap as much as the next guy, but weíre talking about a serious concern (door pops) on 200k+ machines. Do it right. Lights plus latches.
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
Old 11-08-2018, 03:24 PM
Mike,
I didn't say the design mitigated all possible failure modes, and I didn't mean that it is the only way it should be done.
They are experimental airplanes after all... do what every you think is right for you depending on what type of indication system you have to connect it to..
Scott McDaniels
Hubbard, Oregon
Old 11-08-2018, 03:38 PM
I donít remember the technical details, but my door lights through my SkyView system are continuous green for closed and red for open.
Myron Nelson
Mesa, AZ
N24EV
