Old 07-14-2018, 10:03 AM
bryanflood's Avatar
bryanflood bryanflood is offline
Default How do I attach this bolt?
Hey,
not sure what to do with this bolt. It looks like it needs a special narrow nut or something, not sure how I am going to get 1-3 threads past the nut. Any ideas?
Bryan
Old 07-14-2018, 12:03 PM
JonJay's Avatar
JonJay JonJay is offline
Looks like a manufacturing defect?
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-14-2018, 12:15 PM
YellowJacket RV9 YellowJacket RV9 is offline
Gotta be a defect. The grip length (distance from bottom of bolt head to beginning of threads) should be 3 11/16" for AN6-42 if I am reading my chart right. I'll bet yours measures longer. I think you can even see where the grip stops and the threads should go to, but don't.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 07-14-2018, 12:20 PM
It's a little hard to tell from the spec, but it seems that the threads must be at least 7/16" long on an AN6 bolt.
I just measured two that had cotter pin holes drilled. From the good thread at the root to the hole was 3/8" and to the tip end of the thread (from the root) was 1/2".
On mine, an MS21042 nut fit okay for length, and is an approved replacement to AN365 nuts.
I'd be tempted to call them and send yours back for a replacement.
Dave
Old 07-14-2018, 01:12 PM
Sam Buchanan's Avatar
been here awhile
Originally Posted by bryanflood View Post
Hey,
Bryan
Just thread it into one of these....it'll probably be ok........
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 07-14-2018, 07:31 PM
scard's Avatar
scard scard is offline
Thanks Sam, that made my day .
Scott Card
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
Track
