Today I test fit the left wing walk doubler. As the instructions warn, there is quite a gap on the bottom edge because of the curve around the leading edge. How did you earlier fellows handle this? I have the Cleaveland tool with the rollers, so could use that, but I'm wondering if it will be enough. Take a look at this picture: http://www.mykitlog.com/users/display_log.php?user=BigJohn&project=639&category=0&log=77092&row=1
Second issue is whether to prime the top of the wing skin and the bottom of the doubler where they come together. I have opted to prime all internal parts with NAPA 7220, so everything inside the wings except the skins themselves are primed. Following that formula, it seems as if I should have a coat of prime between these mating surfaces, but don't know if it's really necessary, or desireable. Wondering what others have done.
