DHeal
A quick question for our prop gurus: When installing the stock two-blade Sensenich prop on the 912, is the prop's radial orientation with respect to the prop flange of any consequence? For example, is there any potential benefit in "re-clocking" the prop installation on a 912 engine to address a slight perceived prop imbalance/vibration?
With the 912's gearing, it would seem that re-clocking the prop might not affect the prop/engine harmonics the way it does on direct-drive engines??
