-12is stabilator woes...
Roy25101
I have been building the tail kit for the -12is for the last five months and things could not be going any smoother.... until I hit the stabilator. Due, I assume to cracking issues and redesign, it seems Vans has crammed a lot of information and complexity into perhaps too few steps and pictures. I have also started to find that I no longer have a complete set of tools from Cleveland Tools for the -12 kit. I was missing a #20 drill bit and 5/32nd clecos so construction has come to a stop until these arrive.
I just wanted to pass my experience on to potential empenage builders. I went from moving along with minimal mistakes to having to drill out more rivets than I would care to admit. This happened in a very short period of time. Also, it looks like at least a #20 drill bit and 5/32nd clecos will have to be added to the list of required tools.
Happy building...:)
12 stabilizer - mentor
Following info is from my experience only and not meant to be condescending in any way. I offer it free so you may take it for what it cost you.
Yes, you need a few more drill bits, etc., in order to complete your 12 build. And there are a few more that are unlisted and (necessary) in order to build your 12 and some that are (really nice to have) in order to make your build go well - but, in my opinion, the tool that you need the most is a mentor.
In my opinion, Van's does a really good job of listing tools that are required. Some guys could build the metal structure an RV-12 with only a rivet pulling tool and a few socket wrenches and screwdrivers.
I am a builder of houses, cars, mechanical things, etc., but found that my mentor is the reason that I am on the way to completing my 12 build. I have found that assembling an aluminum airplane kit to be completely different than building a house, etc., etc.
There is no substitute for experience here.
That is why I highly recommend that you initiate a search for someone to help you get going on your build. These people exist at your local GA airport - if you can, find someone who has a flying RV. Find one who will help you get started. Getting the right tools is critical - and knowing them correctly is absolutely necessary. Your mentor will gladly help you - find one!
I am finshing up the Finish kit and a couple months ago re-visited the stabilator to address this Service Bulletin. (I decided it was time to do the SB because I was waiting on tools or parts or something for the finish kit). Incidentally, I skipped over my wheel pants, saving them for a time when I have to wait for parts/tools/etc. (and if they remain unfinished by the time the FAR arrives..fine, its an optional thing anyway).
The SB was more work than I thought it would be -- not that it was difficult.. I guess I thought it'd be a 2 hour job..
But like anything, its a lot of putting the part on, drilling, taking it off, deburring, putting it back on.. a few times. And then when you think you're done, you flip the stabilator over and do it all again on that side :) I felt the directions were fine (for the SB, perhaps if you have a newer kit, the SB is baked right into the KAI and may be different than my directions?)
-r
