Old 07-22-2018, 09:33 PM
mikerkba mikerkba is offline
Default AFS ADAHRS pinouts and connections
I'm working vigorously this extended weekend with my A&P on a 5600 and associated components of a quick panel.
I might be overlooking something obvious in the AFS 5000 install manual, but I can't figure out the pinouts for the ADAHRS unit. It is the 9 pin Sub D connector, one end of which came with the connector installed.
And, once the connector is installed, does the cable run from the ADAHRS to one of the SV network jacks on the AFS ACM?
Lastly, both the Dynon radio and the AFS/Dynon autopilot have two SV network jacks? Do both (always) get connected, or need I just connect one to the network hub on the ACM?
Thanks for any help.
Mike Coster
BUILDER: N92MB RV7A (A/W 3/2009) - Sold
ADOPTED/reworking: N4032Q RV8A (8/2017)
KELY/Ely, NV
Old 07-22-2018, 10:00 PM
N402RH's Avatar
N402RH N402RH is offline
http://dynonavionics.com/downloads/advanced/Advanced%20Quick%20Panel%20Installation%20Manual%2 0V5.0.pdf
Page 50 has the SV-Network wiring color code, ADAHRS uses the standard wiring.
Page 89 shows how to connect the SV-Network to the Advanced Control Module and devices. All of the devices with SV Network connections just need to be connected together. The devices that have two SV-Network ports can be used to connect the next device.
Answering from Oshkosh
Rob Hickman
Advanced Flight Systems
Old 07-22-2018, 10:31 PM
Thank you Rob. I wanted to avoid interrupting you at the show.
I've been working from the AF-5000 manual, Ver.15.1, not the ACM manual you linked. That will help a bunch. If we have any questions, we can call the AFS office tomorrow.
Mike Coster
KELY/Ely, NV
