Old 07-13-2019, 03:23 PM
Default PAPR - How Good is Good?
I installed a MUX cable for my uAvionix echoUAT three weeks ago and have good PAPR's on all flights since. I'd like to know by what margin I'm passing the PAPR. Does anyone know minimum limits for each test category?
PAPR from today's flight is below...
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 475
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 07-13-2019, 04:33 PM
snopercod's Avatar
It's my understanding that unless any of those blocks are red, then you passed.
(2019 dues paid)
Old 07-13-2019, 04:45 PM
SPX SPX is offline
I donít know the exact allowance, but I can tell you that depending on your altitude, if you had good ADS-B coverage, you should do better than youíre seeing. 0% in all categories isnít rare.
RV-9A, Carlsbad Ca (CRQ)
Old 07-13-2019, 07:31 PM
moosepileit moosepileit is offline
User guide says highlighted red blocks are fails.
That said, I get all zeros KT-76A and Skybeacon TSO.
Link to FAA PAPR user guide:
https://www.google.com/url?sa=t&sour...SIwz8GbtBlGyDy
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 07-14-2019, 04:41 AM
I usually do get nearly all zeros but this flight was thru central Ohio and down into VW sometimes at lower altitudes and with multiple landings. Plus VW isn't real flat terrain. I think perhaps the low % values are poor radar coverage? Maybe I'm paranoid, but I've been requesting PAPR for every flight and will continue to do so probably thru end of the year.
On a positive note, I had to divert for traffic twice on this flight - once for same altitude nearly head-on.
ADS-B is good...
EAA #499867
