Freakshow108
I have done a ton of research and cannot get a clear answer. I?m so so with electrical. My question is what all should be in the wings before closing?
My plans are:
IFR
AUTO PILOT
This is what I have already done:
Heated pitot tube is installed with tubes ran to root.
Controller for pitot tube mounted on rib.
Ribs are drilled and grommets installed.
Garmin roll servo is installed.
I?m curious as well on what pair wire to run for servo, I know that it needs to be shielded and installation instructions give the AWG but I?m not clear on the number of wires required. Any help would be much appreciated.
My plans are:
IFR
AUTO PILOT
