Old 02-01-2020, 05:21 PM
lon@carolon.net lon@carolon.net is offline
Default How to remove wheel fairings, permanently
After reading the latest Service Bulletins, I removed the nose wheel fairing to inspect the nose fork for cracks. I didnít find any. I also removed the fairings from the main gear tires, in order to give them a careful inspection too. What a job that was, at least for me, possibly because I was working alone, did not have any way to lift the wheels off the ground, and was not the planeís builder, so what I did and saw was all new to me. That done, I decided not to reinstall the fairings. Instead, I plan to replace the fairings with Matco hub caps. I prefer the look of the fairings, but I like being able to see the tires and brakes, and to easily check the tire pressure.
Taking the main gear fairings off exposed the wheel fairing brackets. Theyíre no longer necessary, of course, and they are ugly. They make my plane look like the Roman battle chariots I used to see in movies in Saturday afternoon matinees when I was a kid.
My questions:
1. It looks as though I can remove the outboard brackets and bracket mounts (parts U-00002 and U-00004) simply by unscrewing the two bolts (AN3-37A) that fasten the outboard brackets to the wheels. And it looks as though when I do that, I will not be unfastening the wheel from the plane, because (it appears) the wheel is fastened to the axel solely by an Axel Nut. Is that right?
2. Iím less certain whether I can safely remove the inboard fairing brackets. It looks as though the inboard brackets are fastened to the wheels with four bolts (AN3-4A). But I canít tell whether those four bolts also play a role in fastening the wheels themselves, or the brakes, to the plane. Can I remove the bolts and the brackets without doing anything that makes the wheels and brakes less secure?
Lon Sobel
Santa Monica, CA
RV-12, N58CV
VAF 2020 Dues Paid
Old 02-01-2020, 05:38 PM
DHeal DHeal is offline
These drawings should answer your questions:
https://www.vansaircraft.com/service...revisions/36a/
https://www.vansaircraft.com/service...-revisions/35/
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 890+ hours (as of Mar 2020)!
VAF donation through June 2020.
Old 02-01-2020, 06:08 PM
Might be worth weighing the removed parts, when you're done, and updating the weight and balance document.
Old 02-01-2020, 07:58 PM
Wink
Originally Posted by DHeal View Post
Thanks for your response. These are the drawings I looked at to learn enough for me to write my original post. They taught me some stuff, but left me with the questions I asked, because I didn't build the plane, and because I just can't do anything that might cause the wheels to come off.
Lon Sobel
Santa Monica, CA
RV-12, N58CV
VAF 2020 Dues Paid
Old 02-01-2020, 07:59 PM
Good idea. The RV-12's payload is the best of any LSA I've looked at. But another few pounds (maybe more) would always be nice.
Lon Sobel
Santa Monica, CA
RV-12, N58CV
VAF 2020 Dues Paid
Old 02-01-2020, 08:15 PM
Think of this as an experiment, and save the parts. You may be disappointed in the performance degradation. Unlike the fairings on, say, an old 172, Vans fairings actually work.
Old 02-01-2020, 08:35 PM
Nose wheel fairing, nose strut fairing, and 2 main wheel fairings is actually worth 5 to 7 TAS knots, realistically, at 5200 rpms.
They are very functional items on the RV-12, IMHO. Yes Air press checks and tread checks are a bit more of a PIA. But good retreads will last a whole lot longer than the factory tires sold by Van's.
rgawer probably has the most accurate data of any one here on the improvements the wheel fairings and main gear strut to fuselage and wheel pants fairings make with existing main wheel pants. It's cumulative, and it adds up very fast, the improvements.
Old 02-02-2020, 04:20 PM
dpemmons dpemmons is offline
I also tend to leave mine off since I like to be able to inspect my wheels and brakes, but I leave the brackets since I put the fairings back on when I plan a long cross country. That extra 5-7kts makes a difference when flying 1000 miles.
With practice you get better/faster at taking them off and putting them back on again. I'm at around 10-15 minutes now.
2020 Donation ✔
RV-12 N647RM Bought Flying from Builder
Old 02-02-2020, 04:34 PM
10-15 minutes is remarkable. It took me much longer to get the fairings off, and it seemed to me that putting them back on would be an all-day affair. Do you do something to get the tires up off the ground? I bought an L-shaped screwdriver for the screws on the bottoms of the fairings, but even with that tool, getting those screws out was tricky.
Lon Sobel
Santa Monica, CA
RV-12, N58CV
VAF 2020 Dues Paid
Old 02-02-2020, 07:25 PM
NORM T NORM T is offline
Default My RV-12 Performance
Lon, I agree with Bob's comments, you may be disappointed with the performance. I installed the fairings because I like the appearance, had flown my Grumman Cheetah for nearly twenty years with fairings and wanted to get similar air speed with my RV-12. I am pleased with the results and may have less opportunity for foreign object debris damage to the underside surfaces. I also believe I use less throttle during landing approach. I don't feel a need to use a tire pressure gauge often, but do visually check at preflight. Obviously, the fairings are a matter of personal choice to suit your needs.
