Old 01-09-2020, 06:39 PM
seagull seagull is offline
Default replacing battery with Earth-x
My -12 currently has an Odyssey PC680 battery. It is coming up on 5 yrs, and a bit over 400 hrs. The voltage is 12.2V after sitting a few days. I need to run some tests on it but think it is close to it's end of life.
I am considering getting a EarthX Lithium and was wondering if either the ETX680 or the ETX680C are a direct fit. Do I need to change the battery box also?
Anyone with experience changing over?
Old 01-09-2020, 06:53 PM
Pull your battery, and charge it up with a 12v battery charger for 24 hrs. that will put out 14.8V.
Take it off the charger and take a voltage reading. Should be initially 13.1 to 13.3 volts with a surface charge. Check it quickly, every day, same time of day during the week, 7 days straight.
You should not drop below 12.80 V in 7 days.
Old 01-09-2020, 08:39 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Gull,
To answer your question, I changed from the PC680 to EarthX several years ago. No, it is not a direct fit: The dimensions are not the same, but I was able to modify my existing Vans box to fit the EarthX. I have since changed over to their custom-fit box with the bracket on top to hold a blast tube for battery cooling, and recommend you go ahead and take this route:
https://earthxbatteries.com/shop/the...0-900-vnt-1200
Here's the normal non-thermal box for ETX-680:
https://earthxbatteries.com/shop/aluminum-battery-box
You will absolutely love this battery.
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F NW Regional/Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper
Catch her on YouTube's "Because I Fly!" channel
Proud and grateful 2020 -=VAF=- Contributor
Old 01-09-2020, 11:52 PM
Originally Posted by scrollF4 View Post
Gull,
scroll,
I am sure I will like the battery, the specs are much better than the Odyssey.
Was your application a -12 with the Rotax?
Your 7A with YIO-360M1B may run hotter cowl temps than the 12.
I read Earthx is OEM for the RV-12is, if this is correct there is a Van's battery box or cooling system designed for it. I have the 912ULS, it should produce about the same cowl temps.
Did you connect the battery monitor wire to the supplied LED or to a Dynon input?
ninerbikes,
There is no question the battery is weak, after a full peak charge it reads 12.2V no load. Five years is a long life for one of these batteries considering the use and environment. I am being proactive before it leaves me stranded.
Old 01-10-2020, 03:28 AM
scrollF4's Avatar
Good points, I had not considered the RV-12 application and donít know the answers. Give Kathy a call at EarthX: I bet she knows.
I hard-wired the LED to my panel, because I donít want some EFIS failure to hide a possible problem. The battery light is independent on my airplane.
Scroll
Old 01-10-2020, 05:37 AM
Plummit's Avatar
Plummit Plummit is offline
What don't you like about the Odyssey battery? You are in the luxurious position of replacing a good quality battery on your time, at your leisure, before you have a failure. What are you trying to improve, the 5-year life? The reliability? I would (and did) replace my Odyssey with another Odyssey when it was time.
Just don't buy from Spruce unless you know what you are getting. They sold me a 925 Odyssey that was a year old according to the date code on the battery. They only had one in stock and I had possibly damaged my 3 year old 925 by leaving the master on so I changed it. You just can't beat the price point and reliability of the Odyssey.
-Marc
N814RV
2020 Donation Made
Old 01-10-2020, 05:39 AM
This may not be the case. Legacy RV-12 is tightly cowled and 12iS cowling has louvers for added ventilation. Biggest concern might be on the ground when powered off. Legacy retains heat without adequate ventilation. When I "park" I open the oil door to let heat escape...
Hinckley, Ohio (1OA2)
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 526
LSRM-A Certificate 2016 for RV-12 N633CM
Old 01-10-2020, 07:09 AM
von_flyer von_flyer is offline
Just a datum point. I am currently replacing my Odyssey PC960 with an Odyssey PC960. Battery is 13.5 years in service. It doesn't owe me anything.
New Odyssey has a date code of 19333. Can I assume that means it was manufactured on the 333rd day of 2019?
John von Linsowe
Michigan
Cessna 140
Old 01-10-2020, 07:58 AM
-Marc
There is nothing not to like about the Odyssey, but the Earthx will take 10 pounds off the plane, that is significant on a LSA.
Old 01-10-2020, 08:50 AM
I wouldn't assume anything about a printed date code. Manufacturers often use internal code reference which consumer is not privy too.
EAA #499867
