Attakpilot
Member
GSA 28 autotrim
My current setup has MAC S8 servos with Matronics MkIII governor speed controls from a single coolie hat switch for pitch & roll trim. I am installing a G5 with autopilot. When wiring the GSA 28 for autotrim do I connect the output from the speed control to the servo then from the servo to the motor? The print says to connect pins 11 & 12 to the switch. Not sure if I leave the governors installed should the GSA 28 fail?
