Old 01-25-2019, 09:19 AM
Nihon_Ni's Avatar
Nihon_Ni Nihon_Ni is offline
Karl,
Thanks for the info. What are the other three items on that panel? Two of them look like single plug headset jacks, what's the bigger one aft of the seat heat switch?
Do your pad wires just come up under the stick cover console, or is there a hole in the floor for the wires? I was wondering if there would be an issue with running wires under the seat cushion. I could cut a little relief in the foam to create a channel for them to route under, but I wasn't sure if that was necessary.
Looks like you retained all the OEM wiring, is that right? My power wires won't reach the fuse block up front, so I'll probably replace those, but I'm undecided on replacing the others or not.
Thanks!
Rob
Rob K
真喜志友幸
RV-8 under construction as of Sep 30, 2012
Tail kit completed on Feb 8, 2012 (180 hrs)
Wing kit mostly completed, fuselage under construction as of March 6, 2014 (750 hrs)
Paid up for 2018
Old 01-25-2019, 03:43 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
The two additional plugs are LEMO plugs for the Bose A20 headsets. Ships power for the headsets with batteries as a backup. I need to move the rear headset plug to the fuselage rib to prevent any rear seat passengers from accidentally damaging the plug when they slide their right foot into the footwell. Just haven't gotten around to doing that.
The large plug is a power plug for iPad in flight entertainment. It's a higher quality motorcycle power plug that comes with a dust cover. I put one in the forward cockpit too, next to the seat heat control, fire extinguisher and canopy breaker tool.
http://www.bikerhiway.com/product/ci...-mount-kit-48/
I did retain most of the original wiring harness for the seat heaters. Like you mentioned, the power and ground wires will not reach the fuse panel so I replaced those. I have a separate fuse for each seat heater set.
Pad wires come up under the stick cover. I cut a small relief channel for the wires. No modification was made to the bottom seat cushions.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
Old 01-25-2019, 05:23 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by flightlogic View Post
If your seat is on fire, and you have not turned it off.... you get a D minus for situational awareness. ...
You are assuming the fire goes out when the power is cut.
I would want to do a flame test on an extra set of seat cushions and the seat covering.
Not to mention any noxious fumes that may come from the electrical components / wires.
I get it, like you my wife does not put up with the cold. To solve this, I had some removable wool seat covers made. They work great in the summer or winter.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-25-2019, 06:24 PM
scard's Avatar
scard scard is offline
I guess I never realized how lucky I am. Mine came from Minnesnowda and lives in Texas. She just puts on more layers. "Don't need all that stuff that would burn more fuel."
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 2000+hrs. / Cedar Park, TX
Old 01-26-2019, 08:03 PM
Nihon_Ni's Avatar
Thanks Karl!
Rob K
真喜志友幸
Paid up for 2018
