Old 02-09-2019, 06:05 PM
V111Pilot V111Pilot is offline
Default RV8 wing Dihedral?
How is the dihedral set on an RV-8 wing?
Asking because Iím looking at an -8 and the right wing tip is 1 3/4Ē higher than the left.
Thanks!
Old 02-09-2019, 06:44 PM
Ted RV8 Ted RV8 is online now
Set by center spar and wing spars.
Canít speak to the early models but the later models are set from the factory.
Could be gear legs causing the difference while sitting on the ground.
Old 02-09-2019, 08:20 PM
Jpm757 Jpm757 is offline
May be as simple as uneven tire pressure, or as bad as a tweaked gear leg.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 170+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 02-09-2019, 08:38 PM
Scott Hersha Scott Hersha is offline
Put a level across the longerons laterally, and if itís level, check the tires for equal pressure. This assumes the floor where itís sitting is level. If everything is level and one wing is higher than the other, maybe you should call Vans and see what they recommend.
SH
RV-8
Cincinnati, OH/KHAO
JAN2019
Old 02-09-2019, 09:59 PM
Tommy123 Tommy123 is offline
Default Level
Can't eyeball it. Level airplane to specs by vans then check the wing angles. If it is that out of wack I would suspect some wallowed out wing mount holes and run away.
