Old 02-01-2019, 11:00 AM
jlbpropilot jlbpropilot is offline
Default Aileron rigging and stops
I have mounted my aileron and checked the travel limits. I am on the low end tolerance for aileron down. Just out of curiosity what is supposed to be the travel limiter for the ailerons? In my case the hinge wire that holds the flaps on is acting as the stop. Doesn't seem correct to me. Can someone put my mind at ease? Here are a couple of pictures. Thanks
https://imgur.com/a/I6PyXyi
Old 02-01-2019, 02:04 PM
Wunderon's Avatar
Wunderon Wunderon is offline
my plans page 13A has a small angle on each inboard bracket as the control stop
Dave Grimmer
RV8 firewall forward
Edmonds WA
paid 2018
Old 02-01-2019, 03:05 PM
I ended up doing what many others have and cutting my hinge wire in two, cutting a couple ears of the hinge and inserting the wire from the middle towards each end. Problem solved. Thanks
Old 02-02-2019, 01:13 AM
rv8ch rv8ch is offline
Default aileron stops
Here's how I did it: http://www.rv8.ch/aileron-stops/
Mickey Coggins
http://rv8.ch
Old 02-02-2019, 07:10 AM
Mark Dickens's Avatar
Two discrete issues mentioned here:
First, trim that hinge pin so it doesn't touch the aileron bracket. Mine is trimmed such that it doesn't protrude through the brackets at all, so no touching. The hinge pin is not supposed to be used as a control stop.
Secondly, you install a control stop separately for the aileron, either by following the instructions with a small piece of angle riveted to the bracket or as Mickey did, using a nylon spacer which you can get from many places. I did the same as Mickey and got the perfect sized spacer from McMaster-Carr. You have to install a small bit of aluminum tube inside the nylon spacer as a protective bushing. I find it works very well.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 02-02-2019, 07:52 AM
BillL BillL is offline
More importantly, that spacer carries the compressive load of the bolt. So, don't leave it out.
The travel can be tuned by modifying the diameter of the left and right stop.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 02-02-2019, 09:48 AM
FinnFlyer FinnFlyer is offline
Nice solution! Stop is at end of arm as compared to a stop riveted to aileron bracket which is much closer to aileron pivot bolt -- much less load on pivot bolt. Also can be changed/adjusted without having to drill out and re-rivet the stops. I wish I had thought of that!
Finn
Old 02-02-2019, 02:26 PM
Fantastic. Looks exponentially easier than riveting a piece of angle in there. Thank you to all.
