Old 01-27-2019, 11:20 PM
Berchmans Berchmans is offline
Default GTX 345 Installation
I am installing the Garmin GTX 345 with ADS-B in and out. Aircraft is equipped with Dynon FlightDEK 180 using the 1/4 inch pitot/static tubing system with quick disconnect fittings. Does anyone know what fitting I need to flange up with the nylon fitting on the Garmin's static source to adapt to a quick disconnect fitting?
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2019
Old 01-28-2019, 04:50 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Burke,
The static port connection for the Garmin Altitude Encoder (GAE) option for the GTX 345 uses 1/8-27 ANPT female threads.
A wide range of plumbing fitting options are available to adapt to your existing static tube plumbing.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-20-2019, 03:29 PM
Default Installation complete
I have finished installation of my GTX 345, had a successful test flight and applied for rebate. I have one question regarding installation however if anyone can answer. Everything works except the traffic warning light. I flew close enough to another aircraft equiped with ADS-B to activate the audio warning but the light did not eluminate. I have the light powered from pin 21 with power in from the bus on both 21 and 42. The other light lead is connected to pin 15...thoughts?
Burke Wick
Flying RV 8
Anchorage, Alaska
