Old 01-05-2019, 06:42 PM
Tankerpilot75 Tankerpilot75 is offline
Originally Posted by Saville View Post
Hmm ......cooling. Didn't realize that temps were a factor and that the board could get hot.
Thanks!
Canít say Iíve had a problem BUT anything electrical does generate heat. And where its at there isnít a lot of air circulation.
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, GRT EIS, Garmin 340, 335, Dual 430s, TruTrak 385 A/P with auto level, FlightBox hard wired to WS, Dynon D10A with internal battery (backup EFIS), 406 MHz ELT.
Retired - Living the dream - And going broke!
Old 01-05-2019, 07:28 PM
andrewtac andrewtac is offline
Bought my 8, similar set up as some of the others. The PO wired a kill switch under the panel that must be one for the HOTAS start button to work (top left). I like not having a hot starter, so I am leaving this as is. I was concerned about the flaps switch getting bumped. It is a three position. Up springs forward, there is a neautral position in the middle and from there press down for flaps to extend, but is spring loaded back to neautral. So youíd have to go from up to neautral then bump down and hold to extend them.
Mark Andrew Tacquard
2018 VAF Dues Paid
Old 01-27-2019, 11:26 PM
Berchmans Berchmans is offline
Default Ignition points
I have been routing through my drawings and cannot find the layout for the ignition switch in my RV8. I have the standard ignition sold by Vans. Which terminals on the switch do I want to land the wires from the Infinity Stick Starter button?
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2019
