Stabilized Approach
Inside the FAF, your speed shouldn't vary by more than a few knots, or you're really going to be chasing the GS. In the 9, that means somewhere around 80 knots, or you won't be able to go to full flaps, especially at DH. Any faster, you're going to need a lot of runway or you'll be pulling back up into the clouds. I like to be slow enough to allow me to deploy approach flaps (about 90kts) before I intercept the localizer. Once I start the descent, it's hard to slow down enough to deploy flaps if I haven't already done so.
Make stabilized approaches part of your everyday routine. That way, when you're facing weather down to minimums, you won't be sweating. Just so you understand the impact of higher speeds on an ILS, try carrying 110kts to the DH and see if you can get the airplane on the ground without pitching up. That should drive the point home.
Terry, CFI
RV9A N323TP
