lucaperazzolli
Here in Italy, all the airports are closed for recreational flights.
I'm one of the few lucky guys who has the privilege to reach the airport with job permission (requested here to leave home).
In this privilege, I think to protect the plane with the stuff I have available at this moment :
- remove the battery (or power cable) from the system;
- warm the engine, drain the oil, change filter and check screen filter adding a brand new oil. [oil has 4 months and 30 hours]
Make sense in your opinion putting a fresh oil into the engine (no, I've not access to conservative oil at that moment) ?
Have you some other advice ?
I think that here this situation will stand for a couple of months...at least.
