My opinion - -
you pretty much have to put the wing on and trim it for the type seal you are using. I am not using the original. I very much like the stuff I bought. I took a picture of all the stuff I had out, and as usual, it takes lots of tools. Special - not so much.
Note : I use a 6' table with a packing blanket on it to protect the paint, and just pull it out as needed. When trimming, I only pulled it out maybe 3', and left a short part of the spar still inside. Kept it stable. Used a Dremel with course sanding drum.
The video was unintended, but there are more pictures beyond that.
By the way - I did all this by myself.
Added note : A 90 degree drill atachment seems almost a necessity.
John Bender
John Bender
