Just to add to Jack's findings with dual SkyViews.
We now have around 100 hrs on ours without any issues.
Our normal mode is to operate with both SVs on all the time and the electric fuel pump off during the cruise. Typically we see around 12A of alternator output during cruise. We have lights and often leave the landing light on - be safe be seen...
Nav/com is an SL30 and we have a PS Engineering intercom.
The Rotax alternator does seem to behave a bit like a generator at times - ie output varying with rpm. The main time you see this is on take off or during a touch and go when the rpm goes from idle to max in a couple of seconds. At this time, Savvy Analysis shows a spike in the alternator output of no more than 17A for a nano second.
The two screens work well for us - we also tend to use the P1 screen for PFD and EMS (50/50) and the P2 screen for full page map. There are three of us who own and fly the aircraft and often fly together (two out of the three....) so it's handy to hand over control as and when and swap screen displays.
We have PocketFMS airfield charts USB on the P2 display although this can be changed over in flight.
Works a treat so far and compared to many Rotax powered certified aircraft using standard lights and landing lamps, the lights load is very small in comparison (landing light 1A against 10A for instance).
I appreciate Van's concerns over maxing out the alternator but so far so good - all the evidence is we are well below the limit for 99% of the time.
We do not tend to use the 12v power socket at all - no need to charge an iPad for instance given we have two 10" of screens to provide all the info we need.
Would we do it again like this? Yup!
PS Joeri - cool smoke. When we meet up, I'll lead though....
