Old 06-21-2017, 08:23 AM
bobhope2505 bobhope2505 is offline
Default Are all RV-14 QB Fuse kits taildraggers?
Just need a reality check. Working on my 14A QB fuse, and nearly everything is done for conventional gear. Gear braces for tri gear were included, but even nut plate rivet holes are dimpled where only called out for a taildragger, and the openings for the steps are covered by riveted plates. I understand leaving steps incomplete and letting the builder decide on the gear, but I don't get having to undo steps that need not have been done in the first place. Is this typical?
Old 06-21-2017, 08:35 AM
Logan Logan is offline
My -14A QB fuse seemed to have been built for either type of gear. Some steps were left undone when the choice was one or the other. I don't recall having to undo any work... only go back and do things where there were differences between the models. If you want to let me know which steps you are having to undo, I'll go check to see what I did.
Logan Dent
RV-14A Complete!
Airworthiness cert issued June 27, 2018
Old 06-21-2017, 12:48 PM
All RV-14 QB fuselages are both tail dragger and tri gear.
Any work (for either version) that would have been more difficult to do after fuselage assembly, is done at the expense of builders having to do work to configure to the model they are building.
Scott McDaniels
Hubbard, Oregon
Old 06-22-2017, 08:34 AM
Thanks for the replies. The QB fuse is a work of art. A couple of builders and my adviser gawked at it for 30 minutes when it arrived. One called it "glorious." That said, it would have been nice to have the gear openings cut out when it was a flat piece of aluminum on the CNC laser cutter instead of me using a cutoff wheel on the bottom of my air frame. It doesn't look difficult...as long as my hands don't shake.
Old 06-22-2017, 09:38 AM
Don't worry about the cuts on the bottom. It was surprisingly easy. I made sure to cut a bit short (or long, depending on your viewpoint) and filed down to match the cutout in the mated skin. Easy to make perfect match that way. Hardest part was balancing the fuse.
Logan Dent
RV-14A Complete!
Old 06-22-2017, 01:44 PM
MED MED is offline
I used a nibbler to make almost perfect cuts. Only needed a few minutes with a file to clean them up.
Old 06-29-2017, 12:42 PM
Rteem Rteem is offline
My 14 is also a QB, and I wasn't impressed with countless omitted steps and errors that caused endless frustration. I definitely ended up undoing and/or redoing work that should have been done correctly the first time.
YMMV, but I will probably do a slow build if I build another.
Old 06-29-2017, 01:08 PM
bkervaski's Avatar
@Rteem would love some details on your experience, mine is inbound and it would be great not to have to repeat what you went through. Specifically, errors you had to redo. Also maybe when you received your QB Thanks in advance for any help!
Progress: Flying!
Old 06-29-2017, 07:32 PM
Polar Polar is offline
I have heard this sentiment before, unfortunately. Would you care to elaborate? I'm still undecided regarding slow/quick build fuselage.
