I've read recommendations that extra longerons be included in the wing/fuse order. I'm ready to order RV-7 QB wings and fuselage. Will the longerons already be installed in the fuselage, making this a non-issue?
last month I read in barnstormer that a rv was for sale and it had 1 inch square tube longerons ??? I'm starting my fuse and will look into it. question why and how they did it. btc
I used 1? angle on the -4 I?m building. It helps with the edge distance issue on the tail and engine mount weldment bolt holes. Weight difference is negligible.
I think it would be tough to buck rivets inside a 1" tube... So, either the ad isn't correct (maybe they meant angle, not tube), or the airplane used a LOT of pop rivets attaching skins and the like to those tubes.
