Small favours, I'll take 'em!
sbal0906
So after finally successfully dimpling the aft holes in the R-903 rudder tip rib, I couldn't shake the feeling that maybe I had flexed the flange back and forth a bit too much in the effort of getting something in there to get a good dimple. Maybe it would have been fine to build on but I decided to go ahead and order a new rib now that I had a way of dimpling in that narrow space.
I received the rib to discover the aft 6 holes were already drilled and dimpled! Nice! :)
Modifying tools
We all know what you are dealing with and how many tight spaces there are,
that require access with tools.
Don't be afraid to modify your tools a bit to better accommodate them in tight spaces.
You may need to grind one side of the dimple die just a little to access those spots without distorting the flange. consider getting a second set of dimple dies, one you can modify and one for the 95% of dimpling that does not need altering the shape of the dimple set.
Good luck.
Scott, I took a look at your plane today in the EAA hangar. Your right in the middle of it and it's looking good!
Ha! I was wondering how long it would be before I get mixed up with 'sbalmos'! :D
I'm relatively new here. As much as I'd love to be right in the middle of it, I've been "just getting started" for a few years now but am hoping to accelerate my progress.
Cheers!
Good luck.
Thanks! What I ended up doing was epoxying the female die from the close quarters dimple die set on to a piece of flat steel with a 3/32" hole in the center. Then put the male die in the rod from the C-frame tool and used a hammer to form the dimple.
Cheers.
