Old 11-01-2018, 08:52 AM
smt6 smt6 is offline
Default FlyEFII System 32 install
On a recent start, I came to discover that my Ellison TB had become gummed up and was not delivering fuel. I was away from base and at a busy commercial airport with little resources for help.
One of my first calls was to FlyEFII, who suggested I first check the Ellison. I was stubborn and tried a different gascolator and a couple of other potential easier parts. Robert @ EFII turned out to be correct.
Rather than spend money to overhaul the TB, I decided to go with the FlyEFII fuel injection system. I already had their ignition system, so the process would be smoother, which was nice, because I was AOG away from home.
The plug and play of the FlyEFII System 32 product combined with the customer support is unparalleled in this industry. I genuinely wish other companies would take note and stand behind their products like FlyEFII does.
My plane has become safer, while seeing steady increases in power, or really just unleashing the power that was there. Pre ignition, I was seeing 160 KTAS. After the injection install, I saw 176 KTAS.
Thanks again to the team at FlyEFII for getting me back airborne. Check them out for your ignition/injection solutions.
https://www.flyefii.com
Old 11-16-2018, 05:29 AM
KatanaPilot KatanaPilot is offline
Default Production Versions?
Is FlyEFII shipping production versions of their System 32 or do you have a Beta test unit? I’m looking at both of the better known systems trying to make a determination which (if either) to install on the RV-10 we are building.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction
Old 11-16-2018, 09:03 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Fuel flow
Is your 16 knot speed increase for the same fuel flow and density altitude?
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 250+
2019 Dues Paid
The Dues Paid note is a reminder for me
Old 11-16-2018, 03:22 PM
Seeing about 1.2gph increase based on initial data
Old 11-17-2018, 10:03 AM
M McGraw's Avatar
Default Request
Would you be willing to do a test flight? Since you have an airplane before and after System32, I would like to see your percentage change in two regions.
Find a Density Altitude from a previous flight, run your current configuration at the same MAP/RPM and find the TAS and fuel flow difference. Then run that same flight at the fuel flow of the previous configuration and list the speed difference.
Thank you
Marvin McGraw, 5TN4
Flight hours: 250+
2019 Dues Paid
Old 11-17-2018, 11:27 AM
rcpaisley's Avatar
rcpaisley rcpaisley is offline
Default System32
System32 kits are shipping now.
We have about a 60 day lead time currently due to back orders. But we are working on catching back up to our standard 30 day lead time.
Robert
EFII www.flyefii.com
Protek Performance
Old 11-17-2018, 08:23 PM
Thank you
Give me about a week. Still doing test flights trying to nail down my fuel flow K Factor since that was way off with the removal of red cube. I have all my G3X data so it shouldn’t be hard to compare once K factor is correct
Old 11-18-2018, 05:13 AM
DanH's Avatar
DanH DanH is offline
Robert
When will the System 32 installation and operating manual be available for download?
Dan Horton
RV-8 SS
Barrett IO-390
