Have an EXP2BUS running a Dynon Skyview Classic.
EXP2BUS is wired so the Avionics Buss does not shut down during engine start.
Q1: WIll the starter cause a surge back through the Avionics Buss and connected devices ?
Q2: Does the EXP2BUS filter out such surges before they reach the Avionics Buss ?
Q3: Can the attached Dynon filter out such surges without damaging it ?
Q4: The Dynon does shut down during starting, I assume the Avionics Buss is going down to a low voltage that triggers a reboot.
Trying to understand what is happening, we will have a backup battery for the DYNON which hopefully will maintain continuous operation,
Installation includes seperate Master and Starter Solenoids.
