I am using West System 105 Resin, 205 Fast Hardener, and 406 filler. I am building up the rim around the door opening. Most of the mixture stays put where I place it. A few spots it wants to run and no matter how often I push it back into place it runs again. The other areas do not run. Is it because I 'played' with those areas that run more than I 'played with the areas that do not run? Is there something I can do to prevent the runny areas? Those runny areas are wasted and painful to clean up.
