tomkk
I got a WH-00111 5K ohm dimmer pot with my Avionics kit but I don't see an instruction for it's installation, either in the CD or my hard copy construction drawings. I can see it on the schematics - looks like it plugs into pins 6 & 7 of WH-00031 where it plugs into the Switch module.
I'm building ELSA and hesitate to just place it anywhere and wire it based on the schematics without it being referred to in the construction drawings. Any problem doing that? Where are you all placing it on the panel?
Actually, on closer look, the schematic refers to a ES-00195 5K dimmer pot, not a WH-00111 dimmer pot ...
