Stockmanreef
Why would the plans have you roll the leading edge of the elevator after doing all the other stuff on 09-24 and 09-25? For example, why put on the trim tab and the insert the servo? In particular the trim tab servo. The push rod would be in the way, since the elevator will be on a flat surface..
I plan to roll the edges, then finish off all the other stuff on those two pages.
Just curious on other peoples thoughts. Sorry if this has been discussed in a previous thread.
