Name of control cable fitting that pivots?
lndwarrior
It's been a while since I worked on control cables and I've forgotten whatever I knew about fittings.
The issue is a carb heat cable attachment at the flapper. My cable broke, I believe because of pivoting from a fixed cable clamp.
Isn't there a type of cable clamp fitting where the clamp portion itself pivots to eliminate strain? If so, what's it called?
I've done some internet searches but the lack of a proper term for the fitting makes it difficult to find.
Honestly, I'm not 100% certain there really is such a fitting, but I'm hoping so.
TIA
Gary
