Old 06-21-2017, 08:27 PM
lr172 lr172 is offline
Originally Posted by jakej View Post
2. EGT - one simple check is to see what the fuel flow is at max power takeoff (adjusted for or at sea level) it should be approx 13.5 gals for 160hp & approx 16 gals for 180hp engines -.
This has a good amount of variability based upon your prop and the RPM's your turning. For example in my 320, I cruise climb at 140 MPH, which turns 2550 RPM with my FP. I lean a bit down to around 12.5 GPH (150-175 ROP). I lose a decent amount of power if I don't lean in my initial climb 100 MPH / 2440 RPM / 11.8 GPH. THe FI wants to throw 13.5-14 GPH at it and I lose at least 10% power those higher flows, not to mention the waste. My climb CHT's are under 400.
Do you have EI? Advanced timing will increase your CHTs. The only time I hit 400* is at the very end of a 10,000' climb. This is because the advance keeps increasing as the MAP drops with altitude and this drives up the CHTs even though I am under 75% power.
N64LR
RV-10 in progress
Old 05-09-2019, 02:30 PM
Cwood2000 Cwood2000 is offline
I have to throttle back and increase airspeed to keep my CHT's out of the red (420) on all cylinders, where should start?
Aka YellaDawg
RV4
RV14 in gestation
Old 05-10-2019, 07:47 AM
Paul 5r4 Paul 5r4 is offline
Do a search for high CHT's. There LOTS of info on here for that. The first thing is make sure all baffling is nice and tight. My experience.... I had high temps until i provided a pathway for airflow to get below the point where the cylinder walls and fins literally come together essentially blocking the airflow. I fixed that on number 2 and 3... temp problem solved. Do the search there are plenty of photos to see regarding this.
Paul Gray
Foley, Alabama
N729PG..... 450+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
Old 05-10-2019, 10:51 AM
jrs14855 jrs14855 is offline
Default CHT RED LIBE
CHT red line for most normally aspirated Lycoming's is 500. Recommended high performance cruise limit 435. Recommended economy cruise limit 400.
Before the piston rings are fully seated CHT is a big concern. After the rings are seated not really a concern if kept below the above numbers.
I have around 2500 hours in Pitts Aircraft. About 99% of this was with no CHT installed. Never an engine problem.
Old 05-19-2019, 09:56 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Originally Posted by dan carley View Post
I used a later temperature tool and the cht is off by 55 degrees to high
I ordered a new probe
Well that is good news. What brand or kind of probe (plug gasket or bayonet) and brand and type of gauge (electronic or mechanical). Ordering the wrong type (K or J junction) is a common mistake, even brands of probes can work differently. Probe measures the engine CHT and cold junction ambient temperature at gauge, which the gauge should compensate for. Gauges can be off, especially older analog ones.
Under 400F is ideal for long life. If you are at 400F at high power an/or climb you are in ball park.
Originally Posted by jrs14855 View Post
CHT red line for most normally aspirated Lycoming's is 500. Recommended high performance cruise limit 435. Recommended economy cruise limit 400.......About 99% of this was with no CHT installed. Never an engine problem.
Yep in the day most planes had ZERO cht or egt gauges (certified or experimental). At most one EGT or one CHT was a big deal.... Remember renting planes, getting all excited when the plane had one EGT.... Now if you don't have EGT/CHT on every jug, FF, MPG, full EFIS... you are sad and embarrassed... Ha ha. However keeping it below 400F is goodness. 500F may be absolute red-line but that will eat your cylinders. Anything over 420F for me (hot day, heavy long climb) gets me nervous.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
Old 05-20-2019, 04:25 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
As an FYI - there are certain 'basics' to look at before doing a lot of other troubleshooing here.
1. CHT - it's generally recognised that the baffling directly behind the #3 cyl needs to be stepped of the head are (to give a gap for the air) a search will find the answer.
2. EGT - one simple check is to see what the fuel flow is at max power takeoff (adjusted for or at sea level) it should be approx 13.5 gals for 160hp & approx 16 gals for 180hp engines - mine was 10gal/hr (160hp) until I found out what it needed to be, that caused higher CHT'S in climb. Being a carby version the needle needed to be a different size, on fuel injected engines the fuel control unit needs 'adjusting' by a shop. (my big mistake was thinking that the Lycoming factory new engine was just a drop in item - works for certified airframes but not for homebuilts as the baffling & air intake systems can be/are totally different & resulting in different airflows).
Once the above is sorted then if you still experience high temps you need to look further as to the cause.
Jake,
That should be about 15.5 for the 160HP and about 17.5 for the 180 HP
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 05-20-2019, 05:12 AM
jakej jakej is offline
Ok, I got the incorrect numbers out and the litre to gal conversion - it’s been nearly 2 years, were you asleep
