Just squeezed mine thru a 6' double door
Sorry, don't have the exact number with me, but I recently moved mine into a shop with a double door with a 71 1/2" opening. It had the wheels installed and the axle nuts. It was tight. Work one side in, then slide sideways until you get the other side in. Actual dimension is about an inch short of 8' I think.
Hope this helps.
