These parts are originally made in two pieces, which are then bonded together. If it was my part I would cut it in half, on the original cut line, and then bond it properly. This time you have the advantage of being able to bond it together in place, to match the profile of the aft faring.
1. cut part in half, and rough up the cut lines inside and out with coarse sand paper, tapering the glass to a fine edge.
2. cleco parts on structure and use wadded up paper, foam, etc inside to spread the two pieces until the profile matches the other glass part.
3. using a couple of strips of glass, bond the parts on the outside. This is a temporary patch and will be sanded off later
4. When cured, remove part from airplane and do a nice layup on inside of part, and clecoe back in position until cured.
5. When cured, remove outside patch, feather the edges and bond final layer on outside of part.
This will give you the lightest possible part, with little or no filler, and will perfectly match the aft glass faring.
It takes two to three days as you have to wait for the layups to cure but the actual time spent is minimal.
