Baggage compartment weight
togaflyer
In the Van?s weight and balance paperwork it shows the baggage area max weight at 150 lbs. On the Van?s WEB page site for the -10 specs, it shows 100 lbs max. What max weight for the baggage area do you use.
Baggage
FWIW. The little decal that comes with the aerosport door compartment said 100lbs distributed load for baggage area.
Both numbers have been communicated over the years.
Do the math and figure out your weight and balance. Each aircraft is going to be different.
My understanding is the weight limit is set due to CG constraints, not structural strength.
I was about to ask Scott this very question. So, it?s to protect us from ourselves (for those unable or unwilling to do cg calculations)?
The factory recommended baggage area weight limits are typically because of structural design.
Confirming that the airplane stays within CG limits is the pilots responsibility.
