Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #41
Old 06-20-2018, 03:00 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by Brockster View Post
Steve,
I have system version 3.30 but my Boot block is 2.50 as well as X-Loader. Should it be 3.0 for both? When I check for updates it says there are none available though my buddies show 3.0 for those software packages.
Hello Paul,
The V3.00 boot block change was made to support changes in the factory and is not needed by fielded units using the V2.50 boot block and loader.
You are fine. Just relax and enjoy your Aera 660.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 08-25-2018, 04:35 PM
AllThumbs's Avatar
AllThumbs AllThumbs is offline
Hi Steve,
Any timeline for updates to GDL-39 and AERA 660 to support the new FIS-B data?
RV-6 panel is fine. Just... fine.
2019 VAF dues paid!
Old 09-14-2018, 11:29 AM
noelf noelf is offline
Default Watching hurricane Florence on the Aera660
Cool. Here I am at home near Raleigh, N.C. And can watch the hurricane on my Aera 660 with s/w version 3.3
Thanks Garmin.
Noel
RV-6A N6NF
tip-up
flying
Old 09-14-2018, 03:37 PM
g3xpert's Avatar
Post
Thanks Garmin.
Hello Noel,
Thanks for the report. Hope you come out of this ok!
Just for kicks, I did a side-by-side comparison of Aera 660 internet weather and SXM weather (provided by a GDL 52 running in my house). Both are excellent.
Internet Weather
SXM Weather
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 09-15-2018, 12:51 AM
Mgeiss Mgeiss is offline
Default Shorten or expand GMA 25 cable
I already have an Aera 660 with Antenna GMA 25 MCX which works well, but i need to shorten the Antennacable to 3 feet (Glaresheeld) or to expand it if i mount the Antenna on the Back of the Fuselage. Is it a problem to shorten the Cable and if i want to expand it 6 feet, which typ of cable is the best.
Markus
RV7A QB, TIPUP, TMX-IO 360 flying , D-EMRV, Germany
