Old 09-20-2012, 08:50 PM
RV6Pat RV6Pat is offline
Default Buffing Aluminum
I'd like to restore the shine and take out some minor scratches in my project. Any advice on a buffer and compound to use?
Old 09-20-2012, 09:14 PM
panhandler1956's Avatar
panhandler1956 panhandler1956 is offline
Nuvite. That's what I used!
Brent Owens
EAA Chapter 9 Tech Counselor/Flight Advisor
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 09-20-2012, 09:22 PM
Are there types of buffers, pad sizes or pad types?
Old 09-20-2012, 09:28 PM
WingsOnWheels WingsOnWheels is offline
Are you planning to have a painted or polished finish? If you are planning to paint then dont touch it. You may contaminate the surface causing adhesion problems later.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec), but donated early in Sep'19.
Old 09-20-2012, 09:51 PM
I am planning on painting. I'd like to get some scratches out and some of the years of grime.
Old 09-20-2012, 10:08 PM
xblueh2o xblueh2o is offline
If you will be painting, don't polish.
How deep are these scratches?
If they are superficial they will be removed in the paint prep process.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 09-20-2012, 10:31 PM
The problem isn't so much the polishing, but the chemicals if you use buffing compound or polish. Silicone is not a good mix with paint. Buffing with a clean pad shouldn't be a problem - you will have to rough it up with a scotch guard pad and clean real well before you paint anyway, but don't use polish if you are going to paint.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 09-21-2012, 06:29 AM
Thanks everybody for your advice. Not gonna polish.
Old 09-21-2012, 07:41 AM
Yep, don't polish with nuvite - sorry I thought you were polishing.
Good luck with your project!
Brent Owens
Columbus, OH
N784DE S/N #82614
Old 09-21-2012, 07:50 AM
videobobk's Avatar
videobobk videobobk is offline
I don't know whether it would give the finish everyone is looking for, but I know a quick, easy way to put a pretty good shine on aluminum. I buff it with micro balloons. There is no chemical problem and it does a nice job, and quickly. While you rub, you create incredibly small glass particles that really cut. I wouldn't allow it to get into anything like the engine or bearings, but that would be true of all cutting polishes. Try it on a scrap and see how nicely it works!
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
