BTW Keith, a quick google search says the folllowing....
From a quick look at the install manual dated August 1995, its a standard
King/Aviation format output using RS-232. It's not NMEA. Garmin stuff like
430/530 and older Garmin things like the Apollo/UPSAT also output
King/Aviation format, so if the TruTrak works with them it should work with
the KLX135.
The KLX135 uses the extended sentence format that includes all flight plan
waypoints except when its in OBS mode. The sentence is transmitted once
every 2 seconds. The serial port setting is 9600/8/1/N.
The output is semi-human readable kind of like NMEA, so it can be
instructive to pipe it into your PC if you want to record your flight or
troubleshoot something.
Got word back from TruTrak themselves today that the 135 has too slow
output rate for the DigiTrak to maintain a consistent lock to the GPS.
The aviation data format and baud rate are ok, the information updates
themselves just don't come out of the 135 at a fast enough frequency.
Bummer.
