I'm looking for a bit of advice on how most of you moved ahead with the RV-8 kit.
I'm working on a QB kit with the wings complete but not drilled and installed on the airframe. The fuselage is complete through all of the interior parts and the aft upper skin riveted on. Electrical has begun with the main power distribution done but I'm finding it difficult to complete the secondary power distribution wire runs without avionics and switch locations. I intend to save avionics for the last which leads me to want to save riveting on the forward upper skin until that task is complete. The fuel selector, fuel lines, brake lines, rudder pedals, and fuel pumps are installed.
Obvious major tasks still to complete are:
1) Canopy, Canopy skirt, windscreen, canopy hardware (finish kit is on order)
2) Install the empennage
3) rivet the foward upper skin and build baggage door
4) all things firewall forward ( I have the engine minus a few accessories )
5) Avionics to include all things included with the panel
6) Install the wings
7) Cowling
I currently have the fuselage on a rotiserie but am considering installing the gear legs so I can start working on the engine mount and engine installations.
Obviously there is still tons of work to be done but I'm looking for advice on which order to tackle these things. How did you do it and how might you have done things differently?
Thanks in advance for any advice.
7) Cowling
