added weight from RV-8 paint job?
Sherwin Williams Sky-Scapes aerospace base/clear paint. Same paint Cirrus uses on their planes.
by Midwest Aircraft
added 11 lbs
moved CG aft by .25inches
Before:
After:
This is consistent with what Jonathan McCormick at Evoke Aviation told me as well. About 10 lbs if the painter knows what he's doing!
20-years ago, I used same set of scales to weigh RV-6 after paint that I did before 1st flight. Weight increased 8-pounds so the number of 10-pounds sounds very reasonable to me.
