Old 10-22-2017, 11:29 AM
Robert M's Avatar
Robert M Robert M is offline
Default SkyguardTWX Installation
AS of this writing there is a SkyguardTWX with AHRS system enroute to the house. The installation must be "permanent" in order for the following to be true: “Meets Performance Requirements” of TSO-C154c and FAR 91.227 for 1/1/2020 mandate when installed in Experimental and LSA aircraft. This unit comes with a "permanent" mounting bracket.
I am planning to attach it to the center floor cover of the fuel line going from the fuel selector switch to the electric fuel pump. Platenuts will be used to secure the mount on each side of the existing fuel tubing.
My only dilemma about this installation is the routing of the GPS antenna cable. It has to come up from the floor and make it to a spot on the glare shield, clear view of the sky.
Has anyone come up with a unique way to route the GPS antenna cable so that the "puck" is on the glare shield without having it hanging down in front of the panel? Pictures speak a thousand words.
Robert
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
Phase 1 completeded - FLYING Phase 2
Mosquito XEL kit in garage being built.
Old 10-22-2017, 12:11 PM
Sam Buchanan's Avatar
been here awhile
The GPS antenna for my Stratus ESG ADS-B transponder is located forward of the firewall under the cowl. Performs flawlessly.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 10-22-2017, 01:06 PM
dothetime dothetime is offline
Default Skyguard
I have a Skyguard TWX in my 601XL
Works great
The gps cable is very thin, pretty easy to
Route.
My only suggestion is don’t install a 1090 external
Receive antenna. It was unnecessary
As the rubber duck antenna works fine
To receive 1090 even inside my metal fuselage.
I installed an external antenna and was having
Some problems with my FAA report.
Don at Skyguard suggested using the
Rubber duck antenna and all my problems were
Gone. 1090 ads b transmitters are 200 Watts so
The internal antenna seems to work fine.
Let me know if you have any other questions.
N601XP
