Fits Fitting Fuselage Skins
Av8torTom
Hi all,
I'm trying to fit the F-970 fuselage skins and having trouble with alignment. I've been able to cleco the skin to the 706 and 705 bulkheads, but the aft spar wing attach is not lining-up with the cut-out in the skin
I can cleco the lower (upside down) section of the 705 bulkhead and it lines-up nicely as you can see:
Any thoughts?
Also, can someone send me a picture of what happening here?
Thanks all!!!
OK, Problem Solved
I fit the rear wing spar attach to the skin first and now everything lines-up... whew
