Inventory of Unit parts
E. D. Eliot
Inventory of Power Unit parts
Completed inventory of the Power Unit Kit. Everything is there. Problem is, I have a few parts on hand that are not listed on the inventory paperwork. Called Van's today and was told that their parts come from Dynon without an inventory list. My problem with this is that there is no way for me to tell if Dynon left any parts out of my shipment. Hope that its all there.
I'll list the parts that I have for comparison by other members here;
* WH-RV12-EGT R3 IGNITION R3 EGT WIRING
* WH-00063 R2 WIRING HARNESS
* WH-RV-12-IGNITION RS TWO LEAD WIRE HARNESS
* WH-00062 FOUR WIRE HARNESS
* WH-00096 TWO LEAD WIRING HARNESS
* DYNON SENSOR KIT-1 WIRE CONNECTORS
* DYNON FUEL/FLUID SENSOR PRESSURE SENSOR 1001690-000
* 2 EA - DYNON EGT SENSOR P/N 100405-001 REV L
* ROTAX 992818 RELAY SMALLISH RELAY
* F-00049 SHEET METAL - SMALL
* LOSTEILEKARTON 912 TN 881 055 VOLTAGE REGULATOR
As mentioned above, I'm not concerned by what is here - just don't have any way of knowing what isn't here that should be. Guess I'll call Dynon next week. I'll let you all know what they say.
Thanks, Mike
Appreciate your reply. Guess that if something for which I have no check off list comes up missing, Van's will take care of it. I appreciate your quick reply, Thanks, E. D. Eliot
