Tonight I was starting to roll the leading edges of my -10 elevators.
I used Eric's method documented here for my rudder, and thought it worked really well.
I had a ratchet in the end of the bar closest to the tip rib, which in hindsight wasn't a good idea.
As I rolled the leading edge, the corner of the skin bent backwards (away from the spar) and tore before I had realized it.
This is the result:
Clearly, I need to stop drill this. What else should I do to fix this?
I was thinking that I should create a small rectangular piece of similar thickness of the skin and put it on the inside of this skin riveting around the edges of the piece.
Other thoughts?
This is the result:
Other thoughts?
