Old 09-18-2011, 06:13 PM
CMW CMW is offline
Default My attempt at a plenum
Here's a few shots of my plenum. This has taken forever. I hope it works well.
Chris
RV-8 Wings
Old 09-18-2011, 06:30 PM
RV8R999 RV8R999 is offline
Default very well done
Chris - honestly I don't think you can say "attempt" at all. You solution looks absolutely superb. Very nice.
Old 09-18-2011, 07:07 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Neal Howard
Airplaneless once again...
Old 09-18-2011, 09:33 PM
PaigeHoffart PaigeHoffart is offline
Very nice work!
The only potential gotcha I see is the amount of air you're stealing at the back of #3. I think you'll find your oil is going to run pretty cool with that monster cooler. I have Van's standard cooler with a 4" SCAT in the same location as you do, and a 2" scat for cabin heat is taken off of my #4 baffle.
My #3 CHT wanted to run hot while my oil was on the cool side. I ended up blocking about 50% of the area of the inlet with perforated aluminum. Oil temp went up 10 deg (to where it should be), and CHT went down by 25 deg.
I'm sure you have more air to work with than me, but something to think about anyway.
Paige
Old 09-18-2011, 09:37 PM
rvsxer rvsxer is offline
Very nice. The transition to the stock cowl inlets (vs. the Sam James "rings") is especially well done.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
Manager - Panel Design, SteinAir, Inc.
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 09-18-2011, 09:40 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Very nice!!
Chris,
Very Very nice work. Did you lay up the top from the top of the cowl?
What cooler did you use and did you make the plenum for the oil cooler?
The only thing I see that could be an issue is the inlets being aluminum and mating with the glass. The engine moves and the cowl is fixed. Any insulator between the cowl and inlets?
Again, great work!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N707EE-Building
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 09-18-2011, 09:42 PM
flickroll's Avatar
flickroll flickroll is offline
You could go in business selling that! I'll be your first customer
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 09-18-2011, 10:24 PM
Rivethead Rivethead is offline
Uhh Would you come do my plenum? Is that a brushed firewall I see?
Old 09-18-2011, 10:34 PM
AlphaCharlieBravo AlphaCharlieBravo is offline
Very nicely done. Beautiful workmanship.
http://www.vansairforce.com/communit...5&postcount=13
Arnie Barros
VAF #1401
(N89269) reserved
"Seek to understand before trying to be understood"
Old 09-19-2011, 01:07 AM
Sig600 Sig600 is offline
Wow. That's a **** of an "attempt"
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
