  #781
Old 05-28-2018, 09:01 PM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
I took it off and blended the gap, didn't like the way it looked! Wasn't sure what is was for anyway, seemed silly.
Originally Posted by scsmith View Post
Its a cleaver trick of painting and lighting I hope -- it looks like an -8 without a counterweight on the rudder.
-Wingnut
Rhino driver by trade
RV-8 O-360
Old 05-28-2018, 09:04 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Are you kidding? You took off the rudder mass balance weight? It's there for flutter prevention!
I would strongly suggest you reduce your Vne while you build another rudder (per plans) and get it installed.
Carl N.
Arlington, WA (KAWO)
RV-8, 325 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 05-29-2018, 04:42 AM
Michael White's Avatar
Michael White Michael White is offline
Carl...I think he was joking...the counterweight looks to be there in the picture.
Moose
VAF #136
N424LZ Reserved
Old 05-29-2018, 07:29 PM
Default jesting indeed
Yes, totally joking. Fear not, the rudder weight is there and diligently preventing flutter through all phases of flight, it's just hard to see in that pic! Of note, now that we mention it, I am curious as to actual aerodynamic workings of these protruding weighted extensions. Anyone want to indulge my nerdy side and educate me?
-Wingnut
RV-8 O-360
Old 05-29-2018, 07:51 PM
scsmith scsmith is offline
I will describe the aero-balance benefit after I regain my composure.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 500 in 8-3/4 years
also LS-6-15/18 sailplane
VAF donation Dec 2017
Old 05-29-2018, 08:08 PM
RV8JD's Avatar
I thought you might be kidding, but when I saw you were a Naval Aviator ... I wasn't so sure!
(Just Kidding, just kidding! )
Carl N.
(Pic 1),(Pic 2)
(Pic)
Old 05-29-2018, 09:44 PM
RV8JD's Avatar
Mass balancing the control surface prevents coupling of the control surface rotation mode (the control surface rotating about its hinge line) with the main surface bending or torsion (twist) modes. The coupling of these modes could result in flutter.
The idea with (static) mass balancing of any control surface is to move the center of gravity of the control surface closer to the hinge line. This prevents the control surface from rotating when the main surface that the control surface is attached to (i.e., wing, fin, stab), moves. This prevents the control surface from "driving" the main surface and causing flutter to occur.
On many designs, it is not necessary to fully mass balance the control surface to prevent flutter from occurring within the design flight envelope of the airplane. A fully balanced control surface (100% statically balanced) means the CG of the control surface is exactly at the hinge line. For example, the rudder on the RVs are not fully balanced (the CG is still somewhat aft of the hinge line), and they do not need to be.
There is also dynamically mass balancing the control surfaces, but that is not necessary for our RVs.
BTW, as you know, your F/A-18s control surfaces are not mass balanced. Flutter is prevented by ensuring that there is sufficient actuator load loop stiffness (yielding a high enough control surface rotation frequency to prevent the control surface from coupling with other modes) to preclude flutter from occurring. The actuator load loop stiffness consists of the stiffness of the hydraulic actuator and the structural components that the actuators attach to.
See this post and the embedded video to see what happens when there is insufficient actuator load loop stiffness to preclude flutter:
http://www.vansairforce.com/communit...0&postcount=13
and the pilot is/was on VAF:
http://www.vansairforce.com/communit...2&postcount=19
Carl N.
(Pic 1),(Pic 2)
(Pic)
Old 06-04-2018, 07:21 AM
Carl,
Ha! I love it. Aviation wouldn't be what it is without its banter.
Awesome info! Thank you very much, that was exactly what I was looking for. Much appreciated. And written just at a level to which my smaller Navy brain could still absorb!
-Wingnut
RV-8 O-360
