Old 06-14-2018, 12:21 AM
RandyAB RandyAB is online now
Default Alternator pulley ratio
Can anybody tell me what the pulley ratio would be for an IO540 coupled with a B&C 60amp 460 main alternator? Also, can somebody confirm that the vacuum pad will spin the backup alternator (B&C 462) at 1.3:1? I'm trying to confirm how much amperage to expect from each, particularly the main.
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 06-14-2018, 08:50 AM
lr172 lr172 is offline
There are several pulley ratio calculators online. Just use the outside diameter of each of the two pulleys.
N64LR
RV-10 in progress
Old 06-14-2018, 08:58 AM
Walt's Avatar
Walt Walt is offline
I beleive 3.8 is the correct ratio for most alternators with the large lyc pully.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 06-14-2018, 10:10 AM
Toobuilder's Avatar
Just as a point of reference from another thread of mine:
... if we take the typical 3.25 overdrive ratio of the large Lycoming pulley (9.75/3.0), we see we are spinning the alternator at almost 8800 RPM at takeoff....
To that end, Iíve added a 4.5 inch pulley to my alternator to slow it down. The resulting 2.16 ratio gives me a nice 5850 at takeoff and a comfortable 4750 at cruise
I have only ground run this setup and it seems to have no issue cranking out 40+ amps at 1000 RPM, so I think it will easily put out all I need in actual service
Michael Robinson
______________
RV-8 - Flying
Old 06-14-2018, 10:35 AM
Thanks guys. That alternator should more than handle the loads with those ratios.
Randy P.
1st time builder
2017 dues paid
Old 06-14-2018, 12:24 PM
To that end, I’ve added a 4.5 inch pulley to my alternator to slow it down. The resulting 2.16 ratio gives me a nice 5850 at takeoff and a comfortable 4750 at cruise
I have the 7" pulley on my old narrow deck on the 6. I ended up with a ratio similar to yours. It performs well in all scenarios, except Idle (700 RPM) where the 50 amp alternator falls to about 20-25 amps. This is below my typical load at landing and get voltage warnings on short final as the speed bleeds off and the RPMs drop (FP). All in all, its not a problem.
Thought you might be interested and it's worth seeing what kind of fall off you have at 700.
N64LR
RV-10 in progress
