Old 06-13-2018, 06:49 AM
bkervaski's Avatar
Default RV-14 for "Tall People" issue
All,
There is an couple notable observations surfacing with the pedal control bar if you have it in the most forward position. The forward bar's master cylinder attach tab will hit the aft bar (or the Beringer master cylinder eye-bolts if you are using them like me) before the rudder hits its stops.
You will either need to move the control bar aft a notch or fabricate longer cable linkage pieces. Note that linkage is STEEL and NOT aluminum. Not an engineer, but I don't think an aluminum replacement part here would be wise.
Emarit had a handful of steel linkages made with two additional holes, he's out of them now, but this is a good read:
http://rv-14a.blogspot.com/2017/10/f...e-systems.html
(Thanks Emarit!)
Progress: First Flight Prep
Old 06-13-2018, 07:09 AM
asw20c asw20c is offline
It's rare, but every now and then there is an advantage to being a short s***.
Empennage Complete Except for Tips
Wings Underway
Old 06-13-2018, 02:34 PM
Tom023 Tom023 is offline
I always get confused when referencing fore/aft because sometimes people use the terms relative to the pilot seating position and others the ends of the plane. So, my rudder pedals are positioned closest to the firewall and had the interference issue I installed a set of Es longer linkages and needed two holes to avoid interference but they corrected the problem beautifully. Thanks E!
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed
FWF and avionics in progress
2017 Donation
